Wiesmann hardtop fitment issues.
Novus
Hi, I recently got Wiesmann hardtop with fitting kit (for semi-automatic softtop).
I tried fitting it but the hardtop is moved to one side and because of that it leans on roll hoop.
As far as i know there is no room for front (near the front windshield or Pillar A) movement of the hardtop.
Did any of You encountered simillar issues while trying to fit it?
Unfortunatelly i cant add photos there so i attach link to google drive with photos:
Pictures can be found there
iv looked at your pics, and honestly the only advice i can suggest is the roof over time has warped, possibly by how its been stored.
there is a small amount of movement for adjustment in the rears, you can manipulate into a workable position, the fronts though i cant see much movement.
my hard top, i bolt down the front first, to a snug tight fit, then i press the locking levers for the rear to tighten back up, then go to front agaoin ant tighten the 2 bolts tighter.
when my roof isnt in use, its stored secure upright on a roof stand.
cant be much more help im afraid sorry
also just for a bit of clarity, the rear b pillar (if you can call it that) on mine does have a slight hangover like yours, and i cant see how your roll hoops are hitting the roof, as on mine, also with hoops, has bucket loads of room around them??
you can see the roof is miles away from my hoops?
can you post up what yours look like ??
