S54addict
- Joined
- Jan 20, 2016
- Points
- 95
- Model of Z
- S54 Z3M, Z4M coupe/roadster
Yep me too Mike, wouldn't want to leave any debris in the sump.Even the main dealers use these now but I still prefer to use the old fashioned draining method. You get all the rubbish out that way.
Do you recommend engine flush Tony, I have never used but I'm considering for my next change on the ZIf a dealer employs people that they can't trust to do an oil change without creating leaks then God help us all. We have one of these at work and its main use is for general "sucking out" any leftovers in filter housing etc. after the filter has been removed on all of the Peugeot engines widely used across the car world these days. It was bought to do the early Smart cars which didn't have a drain plug. I cannot imagine how you can get more crap out of an engine using one of them rather than draining hot oil into a drain tray, or is that it? Hot oil.
Confused...If a dealer employs people that they can't trust to do an oil change without creating leaks then God help us all. We have one of these at work and its main use is for general "sucking out" any leftovers in filter housing etc. after the filter has been removed on all of the Peugeot engines widely used across the car world these days. It was bought to do the early Smart cars which didn't have a drain plug. I cannot imagine how you can get more crap out of an engine using one of them rather than draining hot oil into a drain tray, or is that it? Hot oil.
Obviously as you are in the trade you favour the more traditional method. Do you know if the BMW dealers use the top extraction method?Confused...Obviously as you are in the trade you favour the more traditional method. Do you know if the BMW dealers use the top extraction method?
Thanks for that pal, it will be nice to see clear oil on the stickI used it on my Z3 on every other oil change mate, I didn't on my Z4 at the last one but intend to on the next one. Roy always said how quiet the old girl was.
ps. I use Forte products but there are others . . . . . .
I did put a hydraulic valve lifter treatment (Wynns) in it at one change too, that was after using a flush and it was whisper quiet after that. Forte flush you can run in you engine for a day or so as it has very good lubricatin qualities most others do not and need the run and drain method. I put the flush in my Z3 one lunch time and drained it the next day.Thanks for that pal, it will be nice to see clear oil on the stick![]()
Cool, obviously even though the dealer may recommend a product or procedure... They are not always right! But it's good to have an all round viewI don't know personally, but my manager at work used to work at Sopers so I'll ask him tomorrow.
When I bought my Zed 8 years ago, it was an approved used BMW so to maintain the warranty, I had to have it main dealer serviced. At the oil change, I specified that I wanted the oil change done by the draining method. After I collected it, I jacked it up and the drain plug hadn't been touched. That was the last time they had my custom.
