Im having a starting problem with my 1.9?!
frankmasterjam
leeds
I had an issue with my 1998 1.9 z3, a starting problem. it wouldn’t start at all after driving it. we thought it was an immobiliser issue because the starter motor and fuel pump wasn’t getting any feed/power to it, people in this forum said the EWS code on the ecu needs disabling therefore i did send it off for it disabling. when it got back to me, i put ecu back in and yes it started but i went out for an hour started it on and off to check if it was working and it was sound until i got back home and it didn’t start again. so im back to what it was doing previously. does anyone know what it can be.
Sorry. I don't know the answer. Do you have a code reader? What codes are there - I may have asked this on one of your other threads but, I'm getting old and can't remember.
The reason I'm replying now is that you've started 6 different threads on the exact same topic. Any replies you get will now be scattered across 6 threads. I'm sure you're desperate for an answer but it's easier for you if you keep it all in the same thread. If it slips out of view you can pop it back to the top if necessary rather than starting a new one.
