NZ00Z3 submitted a new resource:
How to clean a MDK (M52TU) Throttle Body's Potentiometers - This document will guide you in hoe to clean your MDK throttle body potentiometers
Read more about this resource...
A step by step guide (with Photos) on how to take apart the MDK throttle body used on the M52TU engines and clean the potentiometers. There is also a test sheet at the back of the document, so you can check the potentiometer resistances both before and after cleaning.
