Fan delete completed over the weekend. I am very lucky that my Daughter has a partner who is an excellent mechanic and enjoys working on the Z3. Any references to "we" really mean "he, and I passed the spanners". Thought it may be of interest to share some pictures and words with anybody else thinking of doing this modification.
The parts:
Wahle thermostat (11531437040 from E-Bay - Motormec) and Gates aux belt (5PK908 from Amazon -SparesHQ).
Meyle water pump with metal impeller (313 011 2001 from Amazon), Valeo Service Thermo switch (820319 from Amazon) and Gates main belt (6PK1540 from Amazon). If the belts do not come up on an Amazon search try typing the reference into Google and it may throw up a link to the Amazon page (this is what happened for me).
First challenge was the head dropping off the radiator bleed screw as soon as it was touched. The head had been broken off, a cross head screw put into the stump and the head put back on with sealer. Fortunately we had bought a new plug
(17.11.1.719.384 from local BMW dealer) before starting. Made me wonder when the coolant was last actually changed (I paid for it to be done by a local German car indy "of good repute" when I bought the car 2 years ago)!!
Main belt looking tired at 86,000 miles.
Aux belt looking very tired.
The removal method basically followed the description in this article http://www.zroadster.net/forum/viewtopic.php?
f=18&t=3631. No special tools used to remove the viscous fan though we shocked it off with a big hammer (would not recommend if you are not changing the water pump).
We also needed to replace the seals on the A/C condenser so that came out as well. Perhaps as well considering the accumulation of muck and flies.View attachment 21060
With the front end stripped out access to do the job was easy.
Old thermostat with broken retaining lugs, which explains why the engine never reach full temperature.
New unit with the later style support legs.
Water pumps, old and new. The central hole on each side is threaded (M6). A bolt each in each is used to jack the pump out of the housing.
Nice new belts fitted. Hopefully good for another 80,000 miles.
Old and new temperature switches. Note the difference in the lower horizontal flat section. The old (lighter) switch has a keyway to the right hand side the new one has it to the left. This presumably was to detect if the wrong switch had been installed during manufacture. The radiator was made by Valeo so this feature may not be present on non OEM parts.
The plug where you can see the guide that goes into the keyway next to the "1-" marking. This has to be trimmed off for the plug to fit.
When it was all back together the coolant was refilled, see https://zroadster.org/threads/anti-freeze-which-colour.9093/#post-133977 for more information.
On start up the engine reached operating temperature quickly and the needle was rock steady in the central position. When stationary with increased rpm the electric fan switched in and putting the heater on full blast caused it to turn off, so all seems to be working as expected.
If you are thinking of doing the same job I hope you find the write up of help.
I’ve got all that too, never had a problem on road for years now, but track driving is another story!
If I wasn’t tracking it I wouldn’t bother. Even standing in queues of traffic on hot days the aux fan only works fine.
I’ve just noticed when I used the number you put up for the new thermostat that it’s using the thermostat that opens at 97 degrees. If this is the case then is that why you still run hot on track days?
