@Marvin you can disconnect the cylinder from the hood and go manual to put it up and down. I don't have the hydraulics and it takes very little time to get the hood up ! HTH JIM
You don't need to disconnect Jim, there is a relief screw on top of the pump, just unscrew this and you have a manual roof.
Edit, if you look at the pic in the first post you can just see the t shaped handle of the relief screw![]()
I can only speak to you from once having a Mercedes slk which has a hydraulic hard top that folds into the trunk. The fluid that I had to use for this pump was not ordinary hydraulic fluid but much thinner. I cannot speak for what is used in the BMW. It was very expensive. Frankie@marqueymarxc
My wife is at work and I'm locked out of the garage or I would post pictures.
I used a generic hydraulic fluid bought at O'Reillys and you will need a small 6 ounce or so oil can with a 4 or 5 inch long flexible hose to reach the fill hole in the fluid reservoir. Inside the hole is a metal rod. You will have to pump the fluid slowly as the metal rod will push out the fluid if you pump to fast. The pump works when you press the button on the console. If you can get the Z in an enclosed space and only turn the key enough to get the accessories to turn on then press the convertible top button with the top down you should be able to here the cylinder piston in your left ear.
Hope this helps.
Marvin
I once had to rebuild a hydraulic piston for my top in a Mercedes but I don't know if you can do this for a BMW. However.....@t-tony @oldcarman @Brian4 @Brian H @pgunter @spurs fan in a coupe
Thanks for the information. Relived pressure at the tank and running manually. Top and cylinder piston work great until the fluid runs out. I can hear the fluid gurggerling in the line as I try to get the top up and the fluid runs out. Other than time shouldn't be too costly. Appreciate the links. Couldn't fix on my own without them.
Marvin
