I’ll unbolt the seats and check
…. but could jack the rear end up and with the engine running put it in first and run it slowly …
) and found the brakes not good even though they have been bled 3 times.
never done it before and it looks a nightmare to get it out
Where did you buy the replacement key fibs?This morning I put the new battery in … started first time
Then put a few bits back … the glass for the wing mirrors ( with a bit of grease !!!! ) , the radio, the cargo net in the passenger footwell. and Filled the washer bottle ( no leaks)
Thought of Tony this morning as I dont have a ‘Roadster’ transfer for the top brake light
Then the Postie arrived with my replacement key fob mats
Didn’t take long to swap them over ( after a bit of a mod to allow the ic chip to sit correctly )
Both keys work fine ….
After finding a German/Japanese Specialist garage about 1/2 a mile from my house, The car will now be going in for the ABS pump bleed , check and clear all or any fault codes, Headlight Adjustment , Tracking and MOT the first week of January.
