Bognor Lean-to Project
If I could arrange to drop off Martin’s canister strap, pick up the engine support and then pick up the bits that Andy has for me in the same trip … then that would be a good day out 😂
Another step forward today…..
A bit of welding …. Not by me though =))
Set up the exhaust on the car, and held the bracket in position so it could get a couple if tack welds done.
Then removed it and finished off the weld on the floor.
Martin the Welder…..
Few bits to do before it can be refitted…. One of which is a trip up to see Andy to collect a heat shield, which has to be installed first:banghead:
And 5 plug welds later….
I had to hold a rag soaked in cold water against the panel while it was welded… this stopped any damage to the paintwork on the wing.
The rear wing now ready to be assembled after a careful bit of grinding, cleaning and painting
And a bit different from a week or so ago
The lower edges of the sills being primed and painted.
And No!!! Even I’m not dopey enough to use rattle cans indoors:whistle:=))
They are just drying after a coat of zinc primer
The exhaust will be heat paint sprayed… Then a lot of reassembly can be done….
And I only noticed today that the metal goblins have been as all the old wings and other scrap metal has gone.:thumbsup:
Saves me the hassle if getting rid of it….
The old Bonnet will left out for them in the next day or so.
onwards and upwards:)
Saturday should be breakfast baguette day but stuff needed doing round the house, so decided to set up all the spraying…. And go backwards and forward doing the house stuff while waiting for the various coats to dry.
4 hours later , house clean ( well bloke type cleaning :whistle: ) grass cut , washing done ….but more importantly….
Rear Wing sorted - welds ground down, zinc primer and top coat
Exhaust finished in a heat resistant paint ( see if that prolongs its life )
And the lower half of both sills topcoated
Got to spray them with a lacquer but will leave that till tomorrow . Let the paint harden overnight.
Off to footy this afternoon so thats it for today :)
Sunday…. sills done, exhaust done an old bonnet left outside for the scrappy.
Heated the garage and sprayed the lacquer coat.
Then moved to the kitchen and removed all the masking
happy with those and just as well as sold my new set =))
Removed the back box and sprayed the pipe and the connection piece
And made the use of my stepson and lifted off the old bonnet and put it outside. ( wont be there long=)))
Looks ok at first glance but lacquer peeling and rust eating the sides and front.
Not a lot I could do today … it will all start after next saturday once I have had a trip out to see Andy and Lee :thumbsup: :)
But sometimes when you’re bored, you just get creative…..
Made two canister straps …. And before anyone asks… both ‘sold’
Took about an hour on the first one and about 35 mins on the second.
But I did have a original to copy which made it a lot easier.
Is this heading where I think it's heading Malc.
They look really good.
Might make another couple but not going into production.
The old bonnet.
We should start a sweep stake how long this takes to vanish.
My guess is 3 days.
Going on the amount of Pikeys around here it would go tomorrow.
ps. But it's likely to be swapped for an old Settee and 2 mattresses.=))=))
Nothing planned for today ….so….
the socket was the correct radius for the bends so that was quite lucky
And the steel bar keeping the material straight is actually my fan removal spanner
Bit of fettling , and then primer and satin black.
And thats another two done …. But production has now ceased.
The old bonnet.
My guess is 3 days.
You were close @Lee 4 days !!
The metal goblins arrived this morning…. Didn’t knock , stopped their van, jumped out and one of them tried pick it up…. But had to get his mate to help….. =)) =)) =))
heavier than he thought !!!!
Still saved me the hassle of cutting it up and taking it to the tip.
So what you doing with the Settee and mattresses Malc?;)=))
Do I win a cuddly toy :D
I was hoping to have lots to put on here today …..
On saturday collected a replacement Radiator and the front heat shield from Andy, then over to Basingstoke for breakfast… on to Zedshed to pick up the last Z3M tank strap set from Lee, also dropped off some bits ….. as usual did bugger all , other that talk and slow every else down.. sorry Paul :whistle:, but a bit of help and guidance received from Lee, which will result in more work to do on mine :arghh:…. But better to do it now rather than later ….
As in engine mounts to be replaced!!
So fully armed ready for a Monday morning blitz……. First job… fit the heat shield…. Thats when it all stopped….….. forgot the get the fixings to hold it in=))=))=))=))
Now ordered and picking up in the morning at 8am, Then drop the last Z3M set off in the post at 9am….. then I will get on with doing what I should have been doing today…:eek:
Had an early run out to collect these….
Dropped off the parcel at the post office and got home just in time to receive a parcel….
Heated Seat Pads arrived about 2 weeks early :)
and all I will use of the wiring that comes with it……is this bit
the 4 way connector and about 6 inches of the wiring.
Everything else is already in the car.
Also in the post was a letter asking me to donate £100 to the Surrey Police ….. but they have given me 3 points. ( I assume there is a catalogue that you can chose stuff from when you gave enough points ??? :whistle:)
Should have got on with the 2.8 but had a @andyglym moment :arghh::arghh::arghh: and decided to wash the Kia and the 1.9 instead.
Then having cleaned them I cleared one of the advises in the last MOT for the 1.9
Headlights deteriated and output poor ( on limit)
Not now they’re not :thumbsup:
Just used Tcut to clean them.
To be fair they were pretty bad:whistle:
Could have got on with the 2.8 after all that but went out for a drive and a coffee instead.:):rolleyes:
