On the actuator keep the big blue and white connection. The other connector you unplug and put new connection to the switch, I'll check the relay in a minuteHey Piran
Hit a stumbling block. Clearly something I'm not doing correctly. Handle still works but not isolated when central locking pressed.
Just for clarification the actuator has 2 plugs.
Small one (3 wires) red/black-perm live, white/green, white/blue
Large one (2 wires) blue, white
Are you leaving all these connected and taking a feed from.....in which case....which cable to handle and which to relay.
The latch that I have is the vw 4 wire with manual lever (brown, brown/black, brown/blue, white/green.....which cables are you using for relay and earth.
Currently managing to work the handle with white/green as live andbrown as earth. Other 2 redundant.
Appreciate your help.
Thanks
Steve
I'll see what I can do, but I've ignored the wires that were there and plugged in two new wires. Internally it's just a dual pole microswitch so depending on whether the car is locked or unlocked you will either get pins 1 and 2 or pins 2 and 3 connected so I have two new wires that connect to the switch and the relay such that when the car is unlocked the relay is earthedWould you mind drawing a diagram please.
Are you saying that the wires from the small connector are cut and go to the switch and relay (in which case which wire to switch and which to relay) the red/black wire of the 3 is a permanent live....where does this go.
Many thanks
Front end coming together (still more work to do on the brackets though):
I've glued and fibreglassed the fixings to the bonnet panel and bootlid:
I've put a brace across the front two bolts on the bootlid to make sure there's not so much stress on the fibrelgass.
Now to the boot lock etc. and wiring the lights and boot handle next.
I'm really liking the simplicity of this Piran. The lines look great. I'm now toying with removing my external Triumph chrome hinges and fitting the old zed boot hinges without the gas strut. I managed to get a vw polo bonnet stay with fixing brackets for £10 from my local scrapyard. It's the perfect length and is fitted to the large plastic trim panel at the rear of the old zed boot....so neat and tidy. At a later date I'll add a locator on the boot lid for when the stay is being used.
Great workkeep it up
No ideaLooking good. Haven't got round to wheel liners yet. Do they fit or is there a bit to make up
No ideahopefully I'll let you know tomorrow
To start with I'll polish the gel coat, later I'll spray it.Are you respraying or polishing up the gel coat.
The rear ones more or less fit, just a bit of minor trimming and fettlingLooking good. Haven't got round to wheel liners yet. Do they fit or is there a bit to make up
